Xiaomi Redmi Note 4 review: Setting the benchmark for the budget segment
Quick take:
It's hard to follow up on the Redmi Note 3, but Xiaomi has managed to deliver a great successor in the Redmi Note 4. The phone now comes with more memory and storage, and the design changes make the device feel upmarket. Battery life has also received a boost thanks to the Snapdragon 625 SoC, and the camera is also better than what we saw last year. In short, this is the phone to beat in the budget segment.
The good
  • Class-leading performance
  • Premium design
  • Great battery life
The bad
  • MIUI quirks
  • Fast charging limited to 5V/2A
Here we go
Xiaomi Redmi Note 4 Full review
Xiaomi had a great 2016 on the back of the Redmi Note 3. Over 3.6 million units of the phone were sold, allowing Xiaomi to cross $1 billion in revenue from the country for the first time.
However, competition in the budget segment has intensified, with Lenovo launching a bevy of models in the country last year. The Moto G4 series continues to sell in huge numbers, and the Z2 Plus picked up a discount recently, bringing the cost of the phone down to ₹14,999. For that amount, you get a handset powered by the Snapdragon 820. The Honor 6X — which has a dual camera setup — is slated to make its debut in India next week, and Samsung's Galaxy J7 and Galaxy On Nxt offer a lot of value for their asking price.
To counter the threat, Xiaomi is selling three variants of the Redmi Note 4 in India: the base model has 2GB of RAM and 32GB storage and retails for ₹9,999 ($145), then there's a variant with 3GB of RAM and 32GB storage for ₹10,999 ($160), and the most interesting model is the one with 4GB of RAM and 64GB storage, which is available for just ₹12,999 ($190).
Can the Redmi Note 4 fend off its rivals and solidify its place in this category? Let's find out.
Xiaomi Redmi Note 4 India
Everything you need to know
Xiaomi Redmi Note 4 Specs
Swipe to scroll horizontally
CategoryFeatures
Operating SystemMIUI 8 based on Android 6.0.1 Marshmallow
Display5.5-inch 1080p (1920x1080) IPS LCD panel
2.5D curved glass
401ppi pixel density
SoCOcta-core Qualcomm Snapdragon 625
Eight Cortex A53 cores at 2.0GHz
14nm
GPUAdreno 506 with Vulkan API, OpenCL 2.0, and OpenGL ES 3.1
650MHz
RAM2GB/3GB/4GB
Storage32GB/32GB/64GB
microSD slot up to 128GB
Rear camera13MP with f/2.0 lens
PDAF, LED flash
1080p video recording
Front shooter5MP with f/2.0 lens
720p video recording
ConnectivityLTE with VoLTE
Wi-Fi 802.11 a/b/g/n, Bluetooth 4.1, GPS, GLONASS
Micro-USB, 3.5mm audio jack, IR blaster
Battery4100mAh battery
Fast charging (5V/2A)
FingerprintRear fingerprint sensor
Dimensions151 x 76 x 8.3mm
Weight175g
ColorsGold, Dark Grey, Matte Black
About this review
I (Harish Jonnalagadda) am writing this review after using the Redmi Note 4 variant with 4GB of RAM and 64GB storage for two weeks in Hyderabad, India. The phone was connected to Airtel's 4G network for the first week, and Jio's VoLTE-enabled network for the rest of the review period. The phone was on the MIUI 8 beta channel, and received three updates with stability fixes.
Exquisite
Xiaomi Redmi Note 4 Design and screen
The Redmi Note 4 is roughly the same size as its predecessor, but the design has been significantly altered. The phone now sports an all-metal chassis, with Xiaomi stating that it takes over 30 steps to turn the aluminum block into a finished piece. The phone is slightly heavier than the Redmi Note 3, but the added heft makes a huge difference in day-to-day usage. It's weighted perfectly, and Xiaomi managed to trim the overall thickness by 0.3mm, bringing the phone down to 8.4mm.
The Redmi Note 3 featured ungainly plastic at the top and bottom, but the Note 4 is entirely made out of aluminum. It instead has antenna lines at the back, which provide signal reception while also serving to break up the design. The phone isn't as curved at the back, with the chamfered edges making for better ergonomics.
These are all subtle changes, but they culminate to produce a phone that's vastly different. The end result is that the Redmi Note 4 feels great to hold and use. The overall fit and finish is one that befits a high-end device, and shows how far companies that cater to the budget segment have come.
Rounding off the design, the Redmi Note 4 has a speaker grille at the bottom, and although it is a single speaker, there are two sets of grills for the sake of symmetry. They're joined in the middle by a microUSB port, an odd choice in 2017 considering the industry is moving to USB-C. The Redmi Pro offers the newer USB-C port, and it is likely Xiaomi will switch to the standard from the next generation. At the top, you'll find the 3.5mm jack and an IR blaster.
The Redmi Note 4's design wouldn't look out of place on a high-end phone.
The power and volume buttons are on the right, and they offer decent tactile feedback. The SIM card slot is on the left, and you can either slot in two SIM cards (microSIM + nanoSIM) or a SIM card along with a microSD card. Round the back, the camera sensor and lens module are aligned with the fingerprint sensor, which is slightly recessed.
The front is dominated by a 5.5-inch display, and the addition of 2.5D curved glass makes a substantial difference when using the screen. The hardware navigation buttons are backlit, allowing for easy access at night. The display itself is brighter and has better color accuracy than the Redmi Note 3, and is easily one of the best panels in this segment.
You get the usual Xiaomi additions as well — there's Reading Mode, a blue light filter that makes it easier to read text at night. The mode lets you create a schedule to automatically enable it, and there's also the option of enabling it for selected apps. You can also adjust the color temperature to your liking, and toggle double tap to wake the screen.
All the details
Xiaomi Redmi Note 4 Hardware
Xiaomi has excelled at offering great hardware in its budget phones, and that hasn't changed with the Redmi Note 4. The Chinese variant of the Redmi Note 4 is powered by MediaTek's Helio X20 SoC, but as Xiaomi isn't allowed to launch phones powered by MediaTek processors in India, the local variant is powered by a Snapdragon 625. Although the naming convention may lead one to believe that it is a downgrade from the Snapdragon 650 used in the Redmi Note 3, that isn't the case.
Unlike the 28nm Snapdragon 650, the Snapdragon 625 is built on the 14nm node, resulting in greater energy efficiency. The mid-range chip powers through everyday tasks with ease, and there wasn't any lag or slowdown in the two weeks I've used the phone. The 4GB of RAM also makes a difference when multitasking. The Snapdragon 625 can also handle visually-intensive games Modern Combat 5: Blackout or Asphalt 8 without breaking a sweat.
The Redmi Note 4 handles everything you throw at it with aplomb.
Even though the base model of the handset comes with 2GB of RAM, it is great to see Xiaomi moving away from 16GB internal memory and instead offering 32GB as the base storage. The phone comes with the usual range of connectivity options, including dual-band Wi-Fi, Bluetooth 4.1, LTE with VoLTE, and an IR blaster that lets you control a variety of appliances.
There's no NFC on the phone, but that isn't as major an omission as it is in Western markets. Android Pay is yet to make its debut in India, and it doesn't look like it will do so anytime soon.
The fingerprint sensor at the back is slightly recessed, making it easy to locate it with your finger. Its position beneath the camera module makes it easy to access, and the sensor itself is quick to authenticate. It is an always-on sensor, so you'll be able to unlock the device even when the display is off.
The speaker on the Redmi Note 4 is significantly better than its predecessor, and that's mainly due to its placement. Moving the speaker to the bottom means that it is no longer muffled when lying flat on a surface. The quality from the speaker is average — with sound getting distorted at high volumes — but at least you won't miss any incoming calls or notifications.
Xiaomi Redmi Note 4 MIUI 8
MIUI saga continues
Xiaomi Redmi Note 4 Software
MIUI 8 is Xiaomi's biggest release in a long time, introducing much-needed visual flair along with new customization options. The skin is based on Android 6.0.1 Marshmallow, and the phone is currently on the December security patch. Xiaomi is testing a Nougat preview of MIUI, and will be rolling it out widely in the coming months.
Setting up the Redmi Note 4 is a hassle, as MIUI still doesn't offer a way to restore apps and settings. So you'll have to individually install apps from the Play Store after booting into the phone. Another issue is with the phone's settings, which is a jumbled mess in its current iteration. Settings you'd normally find on other Android phones are inexplicably missing, and the ones that are available aren't located where you'd expect. For instance, if you want to enable installation of apps from outside the Play Store (useful for installing apps like Spotify), you'll have to go to Settings -> Additional settings -> Privacy ->Unknown sources. On most other phones, it is at Settings -> Security -> Unknown sources.
MIUI is frustrating to use at times, but it is packed with features.
Xiaomi is like the Alfa Romeo of phone brands. Its designs are evocative, and its customers are very passionate about the brand. And like all Alfas, Xiaomi's phones end up being quirky and frustrating to use. With the Redmi Note 4, that shows up in the form of annoying lock screen issues.
Lock screen notifications are a hit and miss in MIUI 8. While I receive all Gmail notifications, I'm yet to see one for Google's Messenger or Facebook Messenger. On the subject of notifications, MIUI 8 has a retooled notification shade that shows quick toggles and incoming messages in the same place. You can expand notifications, but doing so requires a zoom in gesture, not the best solution when you're using the phone one-handed.
Then there's the aggressive memory management. I use Minima for live wallpapers, and to get it to work, the app needs to be running in the background. Every time I closed the Minima app, the wallpaper switched back to the system default.
That said, MIUI 8 has a ton of new features and customizability. There's Dual Apps, which lets you run two instances of the same apps, allowing you to run two WhatsApp or Facebook accounts on the same phone. With Second Space, you can set up two profiles on the phone, with each featuring a different home screen. The profiles are sandboxed and use their own distinct data, but you do get the option to move data between profiles.
MIUI 8 also offers video editing tools in the gallery app, there's a new power-saving mode that lets you conserve the battery, and there's a Quick Ball feature that lets you access shortcuts with ease. You can also take scrolling screenshots, convert currency and other units on the fly, and much more.
Eight new features in MIUI 8
There's also a one-handed mode, which is accessible with a left-to-right (or vice versa) swipe gesture across the navigation keys. You can shrink the screen size down to 4.0 inches, 4.5 inches, or 3.5 inches, making it more convenient to use the phone one-handed. Xiaomi also offers several features for the Indian market. The dialer includes caller ID information for the delivery staff of Amazon, Domino's, Zomato, and other brands, making it easier for you to identify incoming calls.
Better than before
Xiaomi Redmi Note 4 Camera
The Redmi Note 4 has a 13MP camera with f/2.0 lens and PDAF. There's a 5MP camera up front that also sports an f/2.0 lens. The camera app is easy to use and comes with a wealth of options, including filters, beautify effects, and a manual mode that lets you tweak the ISO, white balance, and exposure settings. You can also take tilt-shift photos, set a countdown timer, shoot panoramas, and select from various scenes.
The camera does a great job of taking photos in well-lit conditions, and the resulting images are full of detail and offer saturated colors. You get more detail when shooting in HDR, but doing so takes slightly longer to shoot images. Images at low-light turned out decent, but you'll have to put in a lot of effort to get passable shots.
Incredible
Xiaomi Redmi Note 4 Battery life
The 4100mAh battery on the Redmi Note 4 is slightly larger than its predecessor, but the shift to 14nm has led to vastly increased battery life. The phone easily lasts a day on a full charge if you're a heavy user, and more often than not, you'll get a day and a half worth of usage out of the phone.
You can eke out two days' worth of battery from the phone with medium usage that involves a few hours of streaming music, watching videos, and browsing the web. The one downside with the battery is that the Redmi Note 4's fast charging is limited to 5V/2A. That's equivalent to Quick Charge 2.0 speeds, and correspondingly the phone takes nearly two hours to fully charge.
Can't go wrong
Xiaomi Redmi Note 4 Bottom line
Xiaomi didn't try to re-invent the wheel with the Redmi Note 4. Instead, it focused its attention on fixing the few flaws the Redmi Note 3 had — camera and design. In doing so, it created a well-rounded device that offers excellent value for money. The fact that the phone is now available with 4GB of RAM and 64GB storage is an added bonus.
The design of the phone makes it look much more premium than its predecessor, and the chamfers at the back result in better ergonomics. Same goes for the addition of 2.5D curved glass at the front, which ensures that the phone doesn't dig into your palm when you're using it.
If you want a phone with excellent battery life, just get the Redmi Note 4.
MIUI is still resource-heavy and buggy at times, but the latest iteration has fixed several problems from MIUI 7, and the interface in general looks much better. Battery life has also increased, making the Redmi Note 4 one of the best devices in this segment when it comes to battery longevity.
Like its predecessor, the Redmi Note 4 sets the bar for what phones can achieve in the budget segment. This is the phone to beat in 2017.
Get it already
Should you buy it? Absolutely
If you're looking for a budget handset, then the Redmi Note 4 should be high on your list. For just ₹9,999 — ₹12,999 for 4GB of RAM and 64GB storage — you get a phone with a great design and internal hardware, decent camera, and amazing battery life. There's no doubt that Xiaomi will sell millions of Redmi Note 4 units in India. The only question is if the manufacturer will be able to meet the initial demand. For now, the phone is up for sale exclusively on Flipkart.
See at Flipkart
Harish Jonnalagadda
Senior Editor - Asia
Harish Jonnalagadda is a Senior Editor overseeing Asia at Android Central. He leads the site's coverage of Chinese phone brands, contributing to reviews, features, and buying guides. He also writes about storage servers, audio products, and the semiconductor industry. Contact him on Twitter at @chunkynerd.
