Best Stands and Mounts for Google Home Mini in 2019
Google Home Mini
Google Home Mini (Image credit: Android Central)
The Google Home Mini is an impressive little puck that can play music, automate your home and tap into the search powers of Google for only $49 — or $29 if you get it on sale. At either price, it's not hard to buy a few to have them placed at different spots through your house. You could have the Home Minis placed on different tables or shelves, or you can go a step further and have the speakers mounted on your walls. These are the best options for mounting a Google Home Mini!
Which one stands out?
For something quick and easy to install, the Dot Genie Mini Backpack is your best shot. It's just a case of clipping the Home Mini onto the mount. The custom design plug means there's no need to wrap the cable around, giving it a messy look. The result is a clean look, and it also means you can move the Home Mini around the room or from room to room with ease. What's more, it holds up the Home Mini vertically giving you a better visual on the lights and clearer sound from a vertical speaker.
If you don't mind getting your hands a bit dirty and you're are confident in drilling holes into walls, then the Dot Genie Built-in Mount will give you the cleanest look out of all the mounts. You won't have wires sticking out since you'll find the cable through the wall. This is something you have to take into consideration when deciding where to place Home Mini, but the result will be aesthetically pleasing. The built-in wall placement is perfect if you use the broadcast feature on the Home Mini.
Now that you've got your Google Home Mini setup and put away, you can add to its usefulness by checking out some compatible smart home products.
DJ Reyes
