Best Battery Cases for Samsung Galaxy S8
The Samsung Galaxy S8 doesn't have great battery life, so you may be in search of an extra boost of battery life after a long day of use. That's where a battery case comes in real handy, offering you essentially an extra battery pack that's attached to your phone and doubles up with some added protection.
What's our pick?
If you're in the market for a battery case for your Samsung Galaxy S8, there are a lot of different options to choose from. For those who need as much juice as possible, then the ZeroLemon Ultra Case will be for you with its 8500mAh battery.
For those who like the idea of unique ideas or don't want as much bulk, then you would want to take a look at the Mophie Charge Force Case. The ability to remove the battery when you need to or use this with other modules is just something that is unrivaled.
James Falconer
