Best Android phone with removable battery 2024
Quick Menu
As technology advances and matures, it's only natural for some features to gradually disappear as part of that evolution. When it comes to Android phones, one such feature that once used to be standard and has since become a thing of the past, is a removable battery.
Fewer and fewer phones are released these days with a battery that the users can themselves replace, but if you know where to look, there are still many options worth taking a look at. Here are some of the best Android phones with a removable battery. These include upper mid-range smartphones, rugged devices, and even flip-style phones that are throwbacks to the past.
At a glance
Best overall
Fairphone 5
(Image credit: Fairphone)
1. Fairphone 5
Best sustainable and repairable phone all around.
Specifications
Display: 6.46-inch OLED, 1224x2700 pixels resolution
Chipset / SoC: Qualcomm QCM6490
RAM: 8GB
Storage: 256GB, with support for microSD card
Cameras: 50MP + 50MP (rear), 50MP (front)
OS: Android 13
Battery: 4,200mAh removable
Reasons to buy
Modular design
Five years of updates
Sustainable and easily self-repairable
Looks good and works great
Very good price
Reasons to avoid
Not available in the United States
The Fairphone 5 didn't make its way to the U.S., which was severely disappointing for us all. This fantastic modular phone is easily upgradeable and repairable. You even get a kit with tools when purchasing the phone, allowing you to swap out bits and pieces or fix broken parts yourself.
The Fairphone 5 comes with a neat set of specs, featuring the Qualcomm QCM6490 5G chipset, 8GB RAM and 256GB expandable storage, stereo speakers, a 4,200mAh battery, wired 30W fast charging, Wi-Fi, Bluetooth 5.2, NFC, and dual-SIM support.
Users are guaranteed five years of OS updates, meaning the Fairphone 5 will be good until 2031. It's even water resistant, with an official IP55 rating. For €699 (~$764), it really doesn't get much better than this.
Best for U.S.
TCL ION V
(Image credit: TCL)
2. TCL ION V
Full support for all U.S. carriers.
Specifications
Display: 6-inch HD+, 720x1440 pixels resolution
Chipset / SoC: MediaTek 6762V
RAM: 3GB
Storage: 32GB, with support for microSD card
Cameras: 8MP (front), 5MP (front)
OS: Android 13
Battery: 3,000mAh removable
Reasons to buy
Extremely affordable
Works on all U.S. carriers
Very lightweight build
Expandable storage up to 512GB via microSD
Reasons to avoid
Poor performance
Cheap build
TCL isn't here to blow any minds; it just gets the job done for a bottom-of-the-barrel price. You can score the TCL ION V for less than $100 with entry-level specs, as expected in this price range. Surprisingly, the device runs Android 13 out of the box and it's guaranteed one year of support.
The rest of the specs are underwhelming. You get 3GB of RAM paired with 32GB storage, but that can be expanded up to 512GB with a microSD card. The TCL ION V has a 3,000mAh battery and 30W fast charging, which is nice to have in this range.
What makes the TCL ION V best for the U.S. is that you can easily use with any phone carrier like T-Mobile or AT&T. It is also really lightweight, but that's about everything you can expect from this device.
Best rugged
Samsung Galaxy XCover6 Pro
(Image credit: Samsung)
3. Samsung Galaxy XCover6 Pro
This thing could survive the apocalypse.
Specifications
Display: 6.6-inch PLS LCD, 1080x2408 pixels resolution
Chipset / SoC: Qualcomm Snapdragon 778G
RAM: 6GB
Storage: 128GB, with support for microSD card
Cameras: 50MP + 8MP (rear), 13MP (front)
OS: Android 12
Battery: 4,050mAh removable
Reasons to buy
Insanely durable
Great mix of modern features
Removable battery
Five years of software updates
Reasons to avoid
Somewhat expensive for mid-ranger
Slow charging speed
Samsung's creations always rank among the best Android phones, so naturally it has to make an appearance here as well. You'd be surprised to know that the brand does, in fact, make an Android phone with a removable battery. It's called the Galaxy XCover6 Pro and it's usually used by industry professionals like scientists and engineers due to its ultra-robust make.
The Samsung Galaxy XCover6 Pro is a 5G phone powered by the Snapdragon 778G 5G SoC. You get Android 12 out of the box which is upgradable to Android 13 right away. It has a 4,050mAh removable battery paired with 25W wired charging.
Since the Galaxy XCover6 Pro is a rugged phone by design, it boasts IP68 water and dust proofing as well as military-grade resistance to extreme temperatures. You can even use the touchscreen with gloves on. The one caveat is that the device is a little pricey for a mid-range device, and it certainly won't be able to go against top-of-the-line mainstream devices such as Samsung Galaxy S24 Ultra.
Best budget
BLU G33
(Image credit: BLU)
4. BLU G33
Cheap as they get.
Specifications
Display: 6.26-inch IPS LCD, 480x960 pixels resolution
Chipset / SoC: Unisoc 9863
RAM: 2GB
Storage: 16GB, with support for microSD card
Cameras: 5MP + 5MP (rear), 5MP (front)
OS: Android 13 (Go Edition)
Battery: 3,000mAH removable
Reasons to buy
Filthy cheap price
Water-resistant design
Plenty of accessories in the box
Expandable storage
Face unlock and fingerprint reader
Reasons to avoid
Small battery
Underwhelming performance
Doesn't work on CDMA carriers
You may or may not have heard of the BLU. It's a budget phone brand in the North American region with most of its devices priced under $200 to $100 usually. If you want something cheap with a removable battery, the BLU G33 is a good option.
The BLUE G33 has plenty to offer for the price. There are plenty of extra accessories like a case and charger in the box, the device runs Android 13, you get expandable storage, and there are also extras like a fingerprint sensor and face unlock.
Unfortunately, the BLU G33 doesn't work on all U.S. carriers. Still, if you're on a compatible plan and want to have a removable battery in a cheap Android phone, the BLU G33 is a solid pick.
Best flip
Cat S22 Flip
(Image credit: Cat)
5. Cat S22 Flip
Reminiscent of the flip phones of yore.
Specifications
Display: 2.8-inch TFT LCD, 480x640 pixels resolution; 1.44-inch secondary display
Chipset / SoC: Qualcomm Snapdragon 215
RAM: 2GB
Cameras: 5MP (rear), 2MP (front)
OS: Android 11 (Go Edition)
Battery: 2,000mAh removable
Reasons to buy
Very compact
Battery life is amazing
Has Qualcomm Snapdragon chipset
Solid water and dust resistance
Two displays
Reasons to avoid
Internal screen is too tiny
Limited use compared to proper full-sized smartphones
Dumb phones were all the rage back in the day. If you're still attracted by the flip form factor but not willing to spend thousands of dollars on a modern foldable, the Cat S22 Flip could be an interesting choice.
You get all the basic components of a "smart" Android phone, but the body is markedly different from any other Android device seen nowadays. It's even powered by a Qualcomm Snapdragon SoC and has IP68 water and dust resistance. You can expand the storage via microSD and the S22 Flip uses USB-C for charging.
On the other hand, you get proper keypad like the days of yore. There are two displays, one primary LCD screen inside and another smaller black and white panel on the outside. Although the internal display is a touchscreen, its minuscule size makes it really hard to use. You're much better off using the buttons for navigation.
Best secure
Kyocera DuraForce PRO 3
(Image credit: Kyocera)
6. Kyocera DuraForce PRO 3
Keep your data safe and sound.
Specifications
Display: 5.38-inch OLED, 1080x2160 pixels resolution
Chipset / SoC: Qualcomm Snapdragon 7 Gen 1
RAM: 6GB
Cameras: 64MP + 16MP + 2MP (rear), 8MP (front)
OS: Android 13
Battery: 4,270mAh removable
Reasons to buy
Extremely rugged and secure
Supports hearing aids
Works on Verizon
Battery lasts up to 12 days
Good mix of modern features
Reasons to avoid
Extremely expensive
Very chunky and heavy
Kyocera's Kyocera DuraForce PRO 3 is just as strange and out of place in this era as the Cat S22 Flip. Still, for those who need a removable battery, it's one of the best picks.
The company behind the phone specializes in security and tech so naturally, the Kyocera DuraForce PRO 3 excels in this deparment. On top of that, the device is just as rugged as the Samsung Galaxy XCover6 Pro, with military-grade durability and resistance to water, dust, heat, and cold. It has a 4,270mAh removable battery which lasts for nearly 12 days on conservative use. The phone charges via USB-C, has three primary cameras, and even supports wireless charging.
So, there's a lot to love here but what's the catch? Well, you'll have to spend nearly a thousand dollars to get yourself one of these, which is painfully expensive for a phone in this category. It is also very chunky and hefty, so consider that as well when making your decision.
How to choose
Removable batteries exist — you just have to know where to look
Android phones with removable batteries are far less commonplace than they once used to be, but they still very much exist. Overall, the one that we recommend most people pick up is the Fairphone 5. Not only is the battery removable, but the entire rig is modular so you can upgrade, swap, and replace parts whenever it tickles your fancy.
Unfortunately, the Fairphone 5 is not available in the North American market. As an alternative for the U.S. and other North American areas, we suggest the TCL ION V. This entry-level phone has a touch screen, runs Android 13, and performs alright for the price. You can easily remove the 3,000mAh lithium-ion battery by popping open the back plate.
If you need something more powerful, Samsung makes some of the best cheap Android phones. It has created one of the best, most robust phones with a removable battery in the form of the XCover6 Pro. The phone features military-grade levels of durability and is powered by a Qualcomm Snapdragon 778G chipset, which provides a decent amount of processing power for everyday usage.
Namerah Saud Fatmi
Editor — Accessories, speakers, and tablets
Namerah enjoys geeking out over accessories, gadgets, and all sorts of smart tech. She spends her time guzzling coffee, writing, casual gaming, and cuddling with her furry best friends. Find her on Twitter @NamerahS.
